  2. AWR Design Environment
  3. Black screen on AXIEM
  • Subscribers 19
  • Views 2667
TI202504016315
TI202504016315 6 months ago
In my Windows10 desktop environment, EM Structure -> New EM Structure -> AXIEM gives black screen and I cannot see any shapes such as rectangles.
Does any body have the same issue?
Thanks.
  • CurtisAWR
    0 CurtisAWR 6 months ago
    To my knowledge, we don't have current reports of this behavior.
    A few questions:
    > What version of the program are you running?
    > Do your Environment Options (Options > Environment Options > Colors tab) settings look correct?
    > Is it just for AXIEM structures?  Or does it also happen for other kinds of structures (such as EMSight or Analyst or Clarity) as well?
    > Does this persist after a reboot or a repair install?
    If this persists, I would encourage you to open a support case at support.cadence.com.  That way, we can get an AE started trying to troubleshoot this with you.
  • TI202504016315
    0 TI202504016315 6 months ago in reply to CurtisAWR
     Many thanks. Somehow uploading my display screenshot fails, so I place it here.
    http://tkyice.icepp.s.u-tokyo.ac.jp/~tinada/tmp/display.png
    As you can see in the screenshot, the AWRDE version is 24.1 and it says AXIEM, Analyst, and the other EM windows are blacked out, but Circuit Schematics shows correctly.
    This picture was taken right after the re-installation, so all the settings are default.
    Among my four Win10 machines, two show this black screen and the other two work well without this black screen.
    Best regards
  • TI202504016315
    Many thanks. Somehow, uploading my display screenshot fails, so I tell you with text.
    Tthe AWRDE version is 24.1. AXIEM, Analyst and all the other EM show the black screen, but Circuit Schematics works correctly.
    It was checked right after the re-installation, so all the settings are default.
    Among four Windows10 machines I use, two show this black screen and the rest two work well without this behavior.
  • OscPn
    0 OscPn 6 months ago in reply to TI202504016315
    Change the background color, steps are, in AWR:
    Options > Environment Options > Colors > Layout Colors > click on "Background".  And then select the color you want
  • CurtisAWR
    0 CurtisAWR 6 months ago in reply to TI202504016315
    This may be a monitor issue.
    Please try these things:
    1. Update your graphics drivers (they may be out of date).
    2. Turn off GPU acceleration, by going to Options > Environment Options > Project tab.  Toward the bottom of the dialog is a checkbox to enable/disable Graphics Acceleration.  Uncheck the box (for Enable 2D/3D layout view).  And I think just to make sure, you can restart the program with the new setting set.
