  2. AWR Design Environment
  3. Complex FFT Coefficients in System Diagram
  • Subscribers 22
  • Views 1992
AV20241030842
AV20241030842 over 1 year ago
Hi
I am trying to make a system diagram which will have a white noise source as input and want to look at the complex FFT coefficients at a test point later in the system. I was wondering if V_FREQ is the parameter to work with since the V_SPEC seems to output a real value? Also, Is it possible to show the complex FFT coefficients as an IQ diagram?
  • OscPn
    0 OscPn over 1 year ago
    As a starting point you may check the AGC_with_Noise.emp example (File > Open Example...).  For your specific requirements, I suggest file a support ticket on https://support.cadence.com/ with the project attached, and an available Application Engineer will follow up on the case.
