  2. AWR Design Environment
  3. Examples for VNCOR2
  • Subscribers 22
  • Views 2161
Examples for VNCOR2
AV20241030842
AV20241030842 over 1 year ago
Hi
I am wondering if there were any example projects that used the correlated noise sources VNCOR2. I am interested in this block and wanted to understand more on how to use them.
  • CurtisAWR
    0 CurtisAWR over 1 year ago
    I don't think we have any specific examples showing the VNCOR2 element, but there is an example project called Small_Signal_Device_Modeling.emp, showing the similar INCOR2 element hooked up into a circuit.
    That example project features modeling capabilities, and isn't centrally focused on noise analysis; as a result, I would suggest starting with one of our Noise Modeling Test Benches, or one of the other example projects showing noise analysis (found by going to File > Open Example, and filtering on the "Name" column for "Noise").
