  2. AWR Design Environment
  3. Modelithics Qorvo Lİbrary Component Licensing Problem
  • Subscribers 22
  • Views 2247
KK202507285148
KK202507285148 over 1 year ago
Hope everyone is well. For my thesis project, I requested "Modelithics Qorvo GaN Library" for AWR through University Request Form. They accepted it and allowed us to download it. With this library, I have access to variety of components to be used.
I set up the installation for the library to AWR. I think I did not make a mistake because when I want to create a project, I can do it via "File>New With Library>Modelithics Qorvo GaN Library". I can also see the components shared with us in the "Elements>Libraries>Modelithics Qorvo GaN Library" section.
When it first creates the project, it asks "Do you want to add MdlxTQTGaN.lpf as a new LPF or replace the default LPF default.lpf" and I click "Add".
I create the schematic and wanted to drag drop "Qorvo TGF2936 Die" on it, when I drop it, it says "Unable to find LPF Default for schematic HMT_QOR_TGF2936_001" and want me to select an alternate LPF for schematic. It gives two options here. One is "default.lpf" and other is "MdlxTQTGaN.lpf". I chose the second and set up my circuit. It is a basic circuit where I wanted to measure its IV-Curve.
When I run the schematic, it gives an error. It says "MODhqortgf2936_core.S2 : feature HMT_QOR_TGF2936_001 not licensed."
I would be really happy if someone can guide me through this.
Thanks for your time.
Note: A new version for this library came out 3-4 days ago and I did not download it yet. I do not now the licensing problem is related to that or not.
  • OscPn
    0 OscPn over 1 year ago
    Hi KK202507285148,
    This is a Modelithics license issue. Contact the support@modelithics.com to resolve the issue.
