  2. AWR Design Environment
  3. How do I choose the right simulator in AWR?
  • Subscribers 22
  • Views 1152
AnalogMonk
AnalogMonk 5 months ago
Hi all,
When I try to run a simple linear simulation, I see multiple simulator options like:
  • Default Linear
  • APLAC Linear
  • Spectre Linear
At first glance, they all seem to do the same thing (just linear simulation), but clearly they’re not identical.
My questions:
  1. Is Default Linear always enough, or should I be using APLAC/Spectre?
  2. Are these just different engines for the same math, or do they behave differently in practice?
  3. In what scenarios do you switch from one to another?
  • CurtisAWR
    CurtisAWR 5 months ago in reply to AnalogMonk +1
    1. I don’t know off-hand of any specific examples where switching between Default Linear and APLAC Linear shows a noticeable difference in results / performance. However, you can reference this link from…
  • OscPn
    OscPn 5 months ago
    Hi  AnalogMonk,
    For most cases, the default Linear simulator is the fastest and best option.
    In some cases, APLAC Linear subcircuit caching can improve simulation time, so APLAC may be preferred.
    The Spectre solver is available only on Linux.
    Other solver engines are also available, such as APLAC HB in Microwave Office, and VSS has its own separate solvers.
    Depending on the application, you can switch between solvers, and each measurement in AWR automatically enables the appropriate solver.
  • AnalogMonk
    AnalogMonk 5 months ago in reply to OscPn
    Thanks for sharing the details. I have few more questions related to this:
    1. Can you share a practical example where switching from the default linear simulator to APLAC resulted in a noticeable improvement in results or performances?
    2. When I select the spectre simulator on my windows machine it throws an error. However, I noticed that it generates a netlist (.scs). How did it generates without that solve? - snap attached
    3. What is the purpose of 'configuration' button in the simulator settings? Are there any scenario or measurement where we can change that?
  • CurtisAWR
    1. I don’t know off-hand of any specific examples where switching between Default Linear and APLAC Linear shows a noticeable difference in results / performance. However, you can reference this link from the relevant section of the Help Manual to see where APLAC Linear Subcircuit Caching can specifically result in performance improvements.
    2. Note that Spectre will yield a simulation in Linux, and I think you said you are in Windows. MWO in Windows will indeed generate the netlist, but you would need the solver to generate the data simulation, and this is a Linux requirement.
    3. The Configuration menu reflects a list of Simulation Configurations available (either as the Default configuration, or specific Switch Lists, defined by the user). The best way for you to learn about them is to click the “Help” menu on that dialog, and on the resulting Help page, to click again on the Switch View Concepts link in the Configuration row of the table. See this link for more information on how -- and why you might -- set up a Switch List.
