  2. AWR Design Environment
  3. AXIEM EM Structure Window Cut Off – Unable to Access Stackup...
  • Subscribers 21
  • Views 308
AXIEM EM Structure Window Cut Off – Unable to Access Stackup and Substrate Settings
NA202606253023
NA202606253023 4 months ago
I am currently using AWR Design Environment 24.1 (licensed version), but I am facing an issue related to the layout and substrate definition interface.
Specifically, I am unable to define the stackup and substrate parameters because the lower portion of the relevant window is not visible. It appears to be cut off or hidden, and I cannot scroll down or access the bottom section where those settings are normally located.
In addition, the window itself cannot be resized, which makes it impossible to adjust the view or access the missing controls.
Has anyone encountered this issue before, and is there a known fix or workaround (e.g., display settings, DPI scaling, or UI reset)?
