  2. AWR Design Environment
  3. Flexlm license problem
  • Subscribers 23
  • Views 549
RM202504304348
RM202504304348 1 month ago
Anybody had problems with license commented in this way:
"10:51:46 AM   Unable to check out package features. Flex Error: ERROR (LMF-10005): License call failed for feature Interposer_Extract_20, version 25.100 and quantity 1. The license server search path is defined as .... The FLEXnet error message is as follows, FLEXnet ERROR(-5, 234, 0): No such feature exists. Run 'lic_error LMF-10005' for more information.: "
I have a floating license on a server, and I read the license from there. Until now, I performed Axiem simulations without problems, but despite the license will expire next year I received this comment for models simulated recently and running without comments.
Of course, I already restarted PC, license, ... without success.
Can you help me?
  • OscPn
    0 OscPn 1 month ago
    It seems that a valid solver license is either unavailable/expired or was not checked in at the time of simulation.
  • Romolo Marcelli
    0 Romolo Marcelli 1 month ago in reply to OscPn
    Hi. Actually, my floating license file expires next year, and the simulator I'm using has been Axiem for several years.
    Simply, in a couple of days I received this comment also for other models I am studying, and I have no explanation for that...
  • OscPn
    0 OscPn 1 month ago in reply to Romolo Marcelli
    This issue may require further debugging. Please submit a case through the Customer ASK portal at https://ask.cadence.com/ with all the relevant details. An AE will be assigned to work with you on the issue.
