  2. AWR Design Environment
  3. AWR Executable Is Being Blocked by Windows Before It Launches...
  • Replies 7
  • Subscribers 24
  • Views 672
AWR Executable Is Being Blocked by Windows Before It Launches. How Can I Fix It?
AnalogMonk
AnalogMonk 23 days ago
Hi everyone,
I'm trying to install Cadence AWR 26.1, but Windows blocks the executable before the installer even starts and displays a message such as:
“This app has been blocked for your protection. An administrator has blocked you from running this app.”
Interestingly, other executables run normally on the same machine.
What should I check to determine why Windows is blocking the AWR executable, and what is the recommended way to resolve it?
  • CurtisAWR
    CurtisAWR 5 days ago in reply to MR202610193757 +1
    One possible cause here, where the application has been blocked and the Publisher is listed as "Unknown" (see screenshot below), is an expired Microsoft Windows Root Certificate. These certificates…
  • CurtisAWR
    CurtisAWR 23 days ago
    Microsoft Windows security may be blocking new AWR releases due to lack of “Reputation” (i.e. lack of history or low usage). This issue is not isolated to AWR software. This issue should resolve itself once enough reputation has built up.
    Depending on your version of Windows, either Microsoft Defender SmartScreen or Smart App Control may be blocking AWR.
    • First, you should try turning off SmartScreen.
      • Details, and steps on how to do this, can be found here:
        • https://www.technipages.com/windows-11-how-to-enable-disable-smartscreen/
    • If that doesn’t resolve the issue, then check to see if Smart App is installed, and if so, try turning it off.
      • Details, and steps on how to do this, are found here:
        • https://www.makeuseof.com/turn-off-smart-app-control-without-reinstalling-windows/
    Please let us know if this resolves the issue (and if so, which of the steps or settings did fix the issue), so this situation may be shared by other users.
  • CurtisAWR
    CurtisAWR 23 days ago in reply to CurtisAWR
    Also, can you clarify:
    Is the installer being blocked, or is it instead the case that AWR installed correctly, but just won't run?
  • MR202610193757
    MR202610193757 13 days ago
    How to Run the Cadence AWR Installer if Windows Blocks It
    1. Search for Command Prompt in the Windows Start menu.
    2. Right-click Command Prompt and select Run as administrator.
    3. Click Yes when prompted by User Account Control.
    4. In Command Prompt, enter the full file path to the AWR installer, enclosed in double quotation marks (" ").
    5. Press Enter to launch the installer.
    Example:
    "C:\Users\name\OneDrive\Desktop\Hotfix_AWR25.10.080_wint_1of1.exe"
    Note: Replace the example path with the actual location of your downloaded installer. You can find the path by holding Shift, right-clicking the installer, and selecting Copy as path.
    Hope this works for you!
  • CurtisAWR
    These certificates should have been updated through regular Windows updates; however, a stale certificate may exist in the URL cache.
    To clear the cache, try running the following command from the command line:
    certutil -urlcache * delete
  • AnalogMonk
    AnalogMonk 23 hours ago in reply to CurtisAWR
    Thanks CurtisAWR
  • CurtisAWR
    CurtisAWR 10 hours ago in reply to AnalogMonk
    I am curious; is your issue resolved, and if so, is it due to clearing the URL cache, or to another of the other suggestions?  Or do you continue to see the issue?
  • VN202611188623
    VN202611188623 2 hours ago in reply to CurtisAWR
    I have a similar issue, but windows blocks LicLocSetup.exe when i try to configure.
