  2. AWR Design Environment
  3. Possible cause and fix for the case when install of the...
  • Subscribers 21
  • Views 68
Possible cause and fix for the case when install of the AWRDE executable is blocked
CurtisAWR
CurtisAWR 4 days ago
Some users may have seen an issue when attempting to install and run the AWRDE executable.  When trying to install, they see a popup similar to the one shown here, informing them that the application has been blocked.  The application's publisher is listed as "Unknown."
One potential cause of this is that the Microsoft Windows Root Certificate is expired.  These certificates are generally updated through regular Windows updates, but it is possible that a stale certificate may still exist in the URL cache.
To clear the cache, issue the following command from a command line:
certutil -urlcache * delete
