  3. Need a Skill code to get a list of elements under a plygonal...
  • Replies 15
  • Subscribers 136
  • Views 27345
Need a Skill code to get a list of elements under a plygonal shape.
AmitBiswas
AmitBiswas over 17 years ago
I am looking for a comand in skill to get the list of elements under a polygonal shape.
There is a command
dbgetTrueOverlaps(
d_cellView
l_bBox
 here the output of this command is a list of elements. But this command only takes the input as a list of two points.
 I want to give a list of more number of points as input to the code and the output it will return a list of elements under the polygon formed by the list of input points.
If anybody knows how to get it done please repply.
Amit
  • dmay
    dmay over 17 years ago
    The "doneProc" for enterPolygon automatically passes the windowId the points and a t/nil (done) to indicate if the routine was completed or not. Cadence provides hooks for doneProcs or callbacks to some of their interactive routines and these are usually passed a fixed set of arguments. The documentation should explain what these arguments are. If you are having trouble finding the doc (or are too lazy to look it up), you can use the following trick to find out how many arguments are needed and what type of arguments they are:
    procedure(myPolygonDp(@optional a b c d)
       println(list(a b c d))
    This will take an optional number of arguments and default the rest to nil. It will then print out their values. In the preceding example, it would be easy to see that the windowId and points are passed to the routine. It would be less clear what the second argument (done) is since you would simply get a t. There is usually enough information for me to write the routine. The code given in the documentation is self-explanatory since it checks the value of done and draws a polygon in w using pts.
    As for your second question, I have observed the same as you (the last object created appears first in the selectedSet for all objects). I do not know if this will work all the time. A safer approach could be to get a list of all objects in the cell. Call the leHiCreatePolygon code. Then get a new list of all the objects in the cell and identify which object is not in the original set.
    cv = geGetEditCellView()
    polygons = setof(x cv~>shapes x~>objType=="polygon")
    leHiCreatePolygon()
    newPolygon = car(setof(x cv~>shapes x~>objType=="polygon" && !memq(x polygons)))
    -Derek
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     I have to agree with Derek, do not rely on the order of the data retrieved from the database. It is poor programming to rely on an undocumented order which may change depending on spaces in the virtual memory.
    You can also use @rest to get all the arguments regardless of the number and then print them:
     procedure(myPolygonDp2( @rest argList )
           println( argList )
    The second argument is gets set to nil if you cancel the enterfunction so you can clean up your code, such as restoring data as it was before the command started.
    Ted
    - Derek - can you email me directly, I need to get some user input.
  • AmitBiswas
    I wan to create a form where some of the form fields will be automatically evaluated depending upon the other form field value.suppose metal width is one one form field and I want to calculate no. of row of via , will be calculated taking care of DRC in the form itself so that user can take a descision before proceeding further.All the calculation I will do but how to reflect the result of the calculation in the form itself.one example like during instantiating a resistor if width is independent variable, length will be calculated depending upon the vale of the resistor.
  • Austin CAD Guy
     Hi Amit
     Why don't you make this a new topic as it it is different from what we dicussed in this topic and may be of interest to others who will be creating forms. Then I will be able to answer and get the widest audience.
    Ted
  • AmitBiswas
    yes , you are right, I din't think of it.
