  3. What's wrong with necoell? That program doesn't run and...
  • Replies 14
  • Views 7537
What's wrong with necoell? That program doesn't run and Cadence still try to sell it?
archive over 17 years ago
Try to try out the program if it's any good.  ./neocell   it would complains missing library of libsstring.so,  libechelon.so, libwmb.so , what?
Those library names aren't even in Redhat enterprise 5.3 disk..  Do a google search,  no such libraries found either.
obviously, that program is not working and probably nobody ever buy it.  Otherwise how can people not complain about missing some exotic named libraries that can't even found in google.
  • craigth
    craigth over 17 years ago
    Below is the high-level mapping of NeoCell 3.4 features to IC's product tiers and features:
    NeoCell 3.4        IC610 VLS
    NeoCell Constraint System (Editor, Assistant, SKILL API)        >      VLS Common Constraint System
    Cell Planning        >      VLS GXL Cell Planner
    Layout Editor        >      End-Of-Life / Virtuoso Layout
    Mod gens        >      VLS GXL Mod gens
    Interactive Placer        >      VLS XL Interactive Placement
    Automatic Placer        >       VLS GXL Analog Placer
  • Eduard
    Eduard over 15 years ago
    Having tryed to use the VLS GXL with the AMS 0.35 um DK, I feel that functionality of NeoCell was not covered fully in the GXL.
    Particularly, Neocell modgen gave more acceptable results at layout generation of precition analog circuits.
    Is there any document , showing the corresponding mapping in more detail?
  • Eduard
    Dear Andrew,
    did you succeed to to check possibility to start neocell in the RHEL5 envirronment?
     Rgs,
    Eduard
    Eduard,
    I've not tried. I suggest that you contact customer support for this and your previous question.
