  3. Problem with Simulating Design using Spectre
  • Replies 13
  • Views 27114
govilv
govilv over 17 years ago
 I have created a schematic using Virtuoso 6. When I open the ADE, it says "(deLicense-7) Could not get a license for ADE L. Would you like to try to get a higher-tiered license to run this product?"
When I click on Yes, it starts the ADE, but when I set up the analysis and click on "Netlist and Run", it comes out with an error -
"Error Unable to locate 'spectre' executable in the specified path. To set the correct path, use setShellEnvVar() in CIW."
I am new to this kind of problem and when I try to check my spectre version and type "spectre -W" in the CIW, it gives me errors. Am I missing a piece of software or it can be fixed without installing anything else?
Please help. Thank you.
 Raj.
  • govilv
    Thanks Andrew, I appreciate your support and patience. I'll ask my system administrator for this installation.
    Raj.
  • sediyahoo
    sediyahoo over 17 years ago
    Any luck on this?
  • govilv
    I did not try running old spectre with new virtuoso. Instead, I installed MMSIM to do the job.
    Thanks everyone for the valuable suggestions.
    Cheers,
    Raj.
