  3. pnoise analysis - bug in Ocean?
  • Subscribers 129
  • Views 1152
anthonyd
anthonyd over 16 years ago
When I run pss/pnoise analysis in Analog Artisit (IC5.1.41) everything is fine but in Ocean get the following error:
 *Error* eval: undefined function - sevLibrary
I couldn't find this error on Sourcelink - perhaps there is a simple fix?  Ocean works fine with transient analysis...
thanks
Anthony
  • tpylant
    tpylant over 16 years ago
    Most of the people monitoring this forum are going to be more RTL focused. I would suggest posting your question in the Custom IC and/or the RF Design forums.
     Tim
    I agree with Tim. But let me answer anyway...
    This looks like CCR 267646, and was fixed in IC5141 subversion 5.10.41.500.5.98 or later. You could use USR6 or the latest hotfix if you don't have a version later than this available.
  • anthonyd
    thanks Andrew
