  3. Refer to another output equation in ADE
  • Replies 13
  • Views 26582
Grover
Grover over 16 years ago
If I set up the output signals and expressions in Analog Design Environment, is it possible to refer to other expressions in an expression? For example, if I have the expressions
pin3 = (power from the 3.3 V supply)
pin12 = (power from the 12V supply)
can I then define
ptot = pin3 + pin12
in some way?
    In IC614 you'll be able to reorder the outputs by dragging, but before that it's not possible through the UI.
    I do have some SKILL to do this, but it contains private functions, so I don't want to post it in a public forum.
  • ag2888
    ag2888 over 12 years ago
    Is this not possible to do in cadence ic 5.1.41 ??
    It gives me an error saying that the output name is an "unbound variable"
    I explained how to do this in IC5141 in an earlier post in this thread. You need to ensure that the expression is of the form: varName=someCalculation() - i.e. you have an assignment to a variable as part of the expression. Then you can refer to the variable varName in subsequent expressions. You will need to be careful about the ordering of the expressions though - it will not sort things so that the expressions are evaluated in the right order - it will evaluate them from top to bottom.
