  3. ocean script - data print to file
  • Replies 27
  • Subscribers 137
  • Views 31154
jugemu1234
jugemu1234 over 16 years ago
I am very new to SKILL or ocean script . I have problems with following script. Firstly I created this ocean.ocn by ADE>Session>Save ocean script... Then added some lines to output data to file. However it ends up outputing error after successful simulation but I do not know what is wrong with this then tried to figure out by myself but couldnt.
I am sure this would be easy thing to do for some people. Hope someone help me out at the earliest oppotunity.
Thanks in advance.
ocnWaveformTool( 'awd )
simulator( 'spectre )
design( "/netlist")
resultsDir( "/MydfII/simulation/sim_osc2/spectre/schematic" )
path( "/multiplelib" )
modelFile(
'("active_thin.scs" "tt")
analysis('tran ?stop "1.1u" ?errpreset "conservative" ?write "spectre.ic"
?writefinal "spectre.fc" ?annotate "status" ?finalTimeOp t ?maxiters "5"
?threshold "0.0" ?detail "node" ?sort "name" )
desVar( "Lvar" 1 )
save( 'v "/net019" "/dvss!" "/dvdd!" )
temp( 27 )
out = outfile("results.txt" "a")
run()
results()
selectResults('tran)
outputs()
ocnPrint(?output out frequency(clip(VT("/net019"),1u,1.1u)) )
close(out)
  • starsky
    starsky over 16 years ago
    Andrew,
    Thanks a lot. It worked!
    Starsky
  • jugemu1234
    Hi there,
    Ive been trying stb analysis and it would make my life easier if i can do that analysis in script.But there is no special function on calculater to see, say, phase margin from stb analysis. How can I output the text of simulation results for stb analysis? ( how shall I write to retrieve PM of stb analysis in my ocean script code? )
    getData("phaseMargin" ?result "stb_margin")
    will do this. Or
    getData("gainMargin" ?result "stb_margin")
    for the gain margin. Easiest way of finding this expression is to run in ADE, and then use the Result->Direct Plot->Main form. Select the metric you want on the direct plot form (e.g. stb/phaseMargin) and then hit the "Add to Outputs" button). Then double click on the entry in the ADE outputs pane and you can see the expression used - it will be as above.
  • jugemu1234
    Thanks for your reply.
    I wrote codes as you mentioned but I got weird results with following codes.
    PM= getData("phaseMargin" ?result "stb_margin")
    DCgain= value(db(mag(getData("loopGain" ?result "stb"))),0,?histoDisplay nil ,?noOfHistoBins 1 )
    UGF= getData("phaseMarginFreq" ?result "stb_margin")
    Outpus were like followings individually.
    nan       -49.6481            nan
    I have no idea what "nan" means to say and how to make it work properly.
    Maybe you can help me again.
  • jugemu1234
     Wrong simulation.
    Pls forget/delete previous post.
  • imagesensor123
    imagesensor123 over 15 years ago
       it's a pity of missing your discussion, but i learnt a lot from your posts above, i looked through the ocean reference but i didn't find any command can do the "save script" job except sevSaveOceanScript , it's used to save the session script, but for me ,i don't want the "save script to file" form turn up, in another word, i want to apply the "save script"  function in my own procedure, does anyone know if there is this function.
    zfeng
  • imagesensor123
       sorry for posting my question here, i have found there is a discussion here , and it give out an appropriate solution.
    zfeng
