  3. Assura 3.2_USR2 Error
  • Subscribers 130
  • Views 14306
Mohammadreza
Mohammadreza over 16 years ago
Dear All,
We installed Assura software based on installation guide and we followed those steps. Unfortunately, when we run Layout XL, we could
not see the Assura  menu and there are some warnings as following:
Load shared object file /apps/edatools/cadence/assura/tools.sun4v/
assura/lib/libavview.so
*WARNING* dlopen: /apps/edatools/cadence/assura/tools.sun4v/assura/lib/
libavview.so: .so.1: /apps/edatools/cadence/psc_ic5141/tools.sun4v/
dfII/bin/icfb.exe: fatal: relocation error: file /apps/edatools/
cadence/assura/tools.sun4v/assura/lib/libavview.so: symbol
layersDefinePen: referenced symbol not found
*WARNING* Failed to open shared object file /apps/edatools/cadence/
*WARNING* Assura has not been installed in this hierarchy.
we have IC5141on Solaris 8. I wrote "assura -v " in command line and this message came up.
Assura (tm) Physical Verification Version av3.2:Production:dfII6.1.3
:IC6.1.3.500.4
            Release 3.2_USR2
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura version av3.2:Production:dfII6.1.3:IC6.1.3.500.4
12/24/2008 02:
28 (sfsol86) $
sub-version 3.2_USR2, integ signature 2008-12-19-0839
run on D506Sun8 from /apps/edatools/cadence/assura/tools.sun4v/assura/
bin/32bit/
assura on Thu Nov 12 21:01:37 2009
No mcf file specified
*****  Assura terminated abnormally  *****
Could you tell me what`s going on about Assura?
I look forward to hearing from you.
Cheers,
Reza
  • Marc Heise
    Marc Heise over 16 years ago
     Reza,
    I've answered that allready in the comp.cad.cadence group.
    You run the wrong Assura version. You need to install a CDB Version which
    can work with your IC5.1.41.
    Double posting just doubles the effort on our side.
    Marc
  • Mohammadreza
    Dear Marc,
    I didn`t know that this comp.cad cadence group is related to the cadence site.
    Thank you so much for your help. we uninstalled the Aussra OA version and we are downloading the Assura 4 CDB version for IC5141.
    Hopefully, everything is ganna be ok.
    I`ll write the result.
    Reza
  • Marc Heise
     Hi Reza,
     comp.cad.cadence is not related to the Cadence site. It's an open public user group which the company can't control. But I would assume that the most people on comp.cad.cadence also check this forum here and try to help if possible.
    Let us know if the CDBA Assura solved your problem.
     Marc
