  3. How to generate warning messages for transient analysis...
  • Replies 11
  • Subscribers 138
  • Views 25748
How to generate warning messages for transient analysis?
AnnaS
AnnaS over 16 years ago
Hi All,
It's will be great if someone can help me to generate warning messages in transient analysis for transistor devices when a voltage reaches above a certain threshold on the gate. I don't know how can I generate these massages neither from gui nor from ocean script.
Thanks in advance.
Anna
    Sort of. The “assert” statement in spectre can have wildcards in the dev= parameter (see “spectre -h assert”) - but whether you can do what you want probably depends on the ability to describe it with a single wildcard. I don’t think you can use a list of instance names (might need an enhancement request - unless this is a feature which has been added whilst I wasn’t looking at the documentation hasn’t been updated). Probably worth contacting customer support.
    I found a recent CCR 1764574 asking for this - but this was only from June, so hasn't been implemented yet.
    However, in an earlier discussion it was suggest that you should generate all the asserts and then use the querying mechanism that was added in ADE XL, Explorer and Assembler in IC617 to filter the violations to the ones you care about. The view is that it's probably better to generate all the assertions and then filter the ones of interest, in case you change your mind about which are of interest (this avoids having to re-run the simulation).
