  3. Strobing Problem
  • Subscribers 129
  • Views 14406
Strobing Problem
Dushan
Dushan over 15 years ago
 I am running a pss sweep analysis and using strobing to save only certain number of points (50). Then I open the results in a table and save them in csv format for further processing. Sometimes it works perfectly, but sometimes it produces more than one point around some of the time instances (closely spaced - around 1fs or even less), so the total number of points is incorrect (e.g. 52 instead of 50). Any help with this issue?
I am running icfb sub-version 5.10.41_USR5.90.69.
Dusan
    Dusan,
    I've not seen this before. I have seen the case where the strobe points are not precisely on the strobe period - which can happen if there are multiple points (e.g. caused by a boundstep in a verilog-a module) near the strobeperiod. If they're too close, it will just keep one of them and not honour the strobeperiod precisely (note that if this happens, the resulting point will be extremely close, so as not to make any difference in practice).
    What spectre version are you using? You mentioned the icfb version, but it's the  spectre version that is more important (this will appear in the top of the spectre.out log file).
  • Dushan
     Andrew,
    Thanks for your answer. I am using spectre version 6.2.1.431.
    The multiple points are extremely close and the sampled signal values are essentially the same - it just confuses the scripts I am using for the processing of output data. Also, I've seen an even weirder thing happening. For example, the output is supposed to be 50x10 array (50 time points, 10 values of the swept parameter). Instead I am getting a 51x10 array where the first raw has only the first element (the rest of the raw empty), and the last raw has all the elements except the first one. I could not figure out any regularity in all this - when I change sweep range or swept variable it disappears.
     Regads,
    Dusan
