  3. vdd not sensed in post-layout simulation
  • Subscribers 129
  • Views 14278
Malolo
Malolo over 15 years ago
I tried to  do post layout simulation with extracted, symbolized inverter, however, I got the message during simualtion:
Notice from spectre during topology check.
Only one connection to node 'vdd!'
I plot the output and confirmed that vdd is not applied to the internal transistors of the inverter, so how to fix this problem?
thanks!
Kevin
    Was the extracted view created with Diva or Assura? If Diva, there was an issue because Diva does not extract a net named vdd! as being global (which is reasonable, because it doesn't know it's global, and actually there is no such thing as a global net in layout).
    The workarounds were either to not use global nets in layout (globals are bad anyway, because they prevent reuse), or to use the following SKILL code.
    BTW, you can spot if this is the problem by looking in your simulation netlist, and if the gnd! and vdd! have been renamed to be different from the vdd!/gnd! in the top cellView, that's the problem.
    Here's the SKILL code. You'd open the extractred view, and then call abMakePlingNetsGlobal().
    /* abMakePlingNetsGlobal.il
    Author A.D.Beckett
    Group Custom IC (UK), Cadence Design Systems Ltd.
    Language SKILL
    Date Mar 11, 1998
    Modified Jan 12, 2010
    By A.D.Beckett
    Make sure that any nets named as being global, really
    are global.
    Updated to use dbSetConnCurrent to make it more portable.
    SCCS Info: @(#) abMakePlingNetsGlobal.il 01/12/10.11:33:23 1.2
    * (abMakePlingNetsGlobal @optional (cellView (geGetEditCellView))) *
    * Make sure that any net ending with "!" is marked as a global *
    * net. *
    (procedure (abMakePlingNetsGlobal @optional (cellView (geGetEditCellView))
    (viewName "extracted"))
    (let (globs)
    (if (equal (dbGetq cellView viewName) viewName)
    (progn
    (printf "Processing cellView %s/%s/%s\n"
    (dbGetq cellView libName)
    (dbGetq cellView cellName)
    (dbGetq cellView viewName))
    (unless (dbReopen cellView "a")
    (error "Failed to make cellView editable\n"))
    (setq globs
    (setof sig (dbGetq cellView signals)
    (when (equal (index (dbGetq sig name) "!") "!")
    (dbSetq sig t isGlobal)
    (when globs
    (printf "Made the following nets global:\n")
    (foreach glob globs
    (printf " %s\n" (dbGetq glob name)))
    (dbSetConnCurrent cellView)
    (warn "%s/%s/%s is not an extracted view\n"
