  3. Not able to generate the antenna info for hard blocks
  • Replies 13
  • Views 22943
tswong
tswong over 16 years ago
I've done the steps below to generate the antenna info on abstract generator, but it is fail so far..
1) define the thickness and defaultantenna rule for electricalRules section on techfile.
2) turn on the signal tab of Extract step
3) define "drain" and "gate" for antenna calculation
There is no error message during the generation, but it is still not able to find any antenna information at the exported LEF. I am not sure whether anything is missed. I wonder anyone could give me advise!
  • Quek
    Quek over 16 years ago
    Hi TS
    One correction:
    For "and" operation, the layer order does not matter. So this is also correct:
    POLY1 = DIFF and POLY1
    You have to also define connectivity in "General" tab of "Extract" step:
    (NDIFF METAL1 CONT)(PDIFF METAL1 CONT)(POLY1 METAL1 CONT)...
    Best regards
    Quek
  • tswong
    Quek,
     I think we have moved a big step, some antenna info can be generated, But I am still confuse about the usage of "Layer Assignment for Antenna regions" and "Use different layer assignments for antenna calculations only" Could you explain more in details?
    For my case, 3 different type of diffusion are used, DIFF, NDIFF and PDIFF. should I define the gate and drain area as below:-
    POLY1 = POLY1 and (DIFF or (NDIFF or PDIFF)) -- GATE
    DIFF = DIFF andnot POLY1 -- DRAIN
    PDIFF = PDIFF andnot POLY1 -- DRAIN
    NDIFF = NDIFF andnot POLY1 -- DRAIN
    POLY1 POLY1
    NDIFF NDIFF andnot POLY1
    PDIFF PDIFF andnot POLY1
    DIFF DIFF andnot POLY1
    CONT CONT
    "Layer connectivity"
    (METAL1 METAL2 VIA12)(METAL2 METAL3 VIA23)(METAL3 METAL4 VIA34)(METAL4 METAL5 VIA45)(METAL5 METAL6 VIA56)(DIFF METAL1 CONT)(NDIFF METAL1 CONT)(PDIFF METAL1 CONT)(POLY1 METAL1 CONT)
    By the way, I notice antenna info for version 5.4 and version 5.5 are different. Do you know the details?
    Regards, TS
  • Quek
    Hi TS
    You need to define the layers that make up antenna regions "gate" and "drain" so that abstract generator can know the area of gates and diffusion. Otherwise, it would not be possible for it to give parameters such as "ANTENNAGATEAREA". : )  The antenna layers need to be assigned so that abstract generator knows the area and type of metals that are connecting to the gate and diffusion.
    I think your inputs for antenna regions and calculations looks ok. You should not have any problems now. There are indeed some changes in antenna info between lef5.4 and 5.5. I do not have all the details but if you look at $CDSHOME/doc/lefdefWN5.5/lefdefWN5.5.pdf, you will find that pg18 states that ANTENNASIZE section has been removed in lef5.5. This section used to contain ANTENNAINPUTGATEAREA, ANTENNAINOUTDIFFAREA and ANTENNAOUTPUTDIFFAREA parameters.
    Best regards
    Quek
