  3. Spectre custom model
  • Subscribers 129
  • Views 14043
pitter
pitter over 15 years ago
 Hi!
I would like to simulate a delay line in a behavioral manner. I need its functionality as a programmable delay, but I do not want to design it from scratch (using buffers, designing on transistor level) I assume it could be done with VHDL, am I right? How can I incorporate the described model into spectre simulation environment. I mean, that I use the delay line model as a block that I can place it amog other standard library component, like, counters, DFFs. Is there any helpful tutorials you would recommend?
Any help appreciated.
 Kind Regards,
 piterS
    If you want to write a behavioural model for spectre, you'll need to use Verilog A, not VHDL. You can:
    1. Look at the examples in <ICinstDir>/tools/dfII/samples/artist/ahdlLib - add this to your cds.lib
    2. Look in the Verilog A documentation in <MMSIMinstDir>/doc/veriaref/veriaref.pdf
    3. Read this book.
    4. Attend a Verilog A Training Class. I just gave the link to the classes in Europe, but you can look in the course catalog for other regions (look at the Support & Training link at the top of the page).
