  3. Monte Carlo simulation correlations definition puzzle
  • Subscribers 129
  • Views 15129
lunren
lunren over 15 years ago
 Dear All,
 I know in Monte Carlo simulation, we can define the correlations between two devices. Now in the simulation, I  have two instances of same module called "PGA", in the Monte Carlo simulation, I want check the mismatch effect inside module "PGA", but I don't want any mismatch between the two instances of module "PGA", in another word, I want the two instances of module "PGA" to be perfect matching (or the same) in the Monte Carlo simulation. Can anyone give me some idea how to do that?
 Devin
  • lunren
     Dear All,
     I know in Monte Carlo simulation, we can define the correlations between two devices. Now in the simulation, I  have two instances of same module called "PGA", in the Monte Carlo simulation, I want to check the mismatch effect inside module "PGA", but I don't want to have any mismatch effect between the two instances of module "PGA", in another word, I want the two instances of module "PGA" to be perfect matched (or the same) in the Monte Carlo simulation. Can anyone give me some idea how to do that?
     Devin
    Devin,
    What version of the IC environment are you using? I think this is possible with the Monte Carlo options in IC614 (and later IC613 versions) from within ADE XL. You can specify which devices/blocks have mismatch applied.
  • lunren
    My IC environment is IC5141. I didn’t find anywhere to specify the correlation block-wise. I did find we can specify the correlation transistors-wise, however, there are too many transistors in the blocks to specify.
    Devin
    I don't think this is possible in IC5141. Whilst the spectre monte carlo analysis allows you to do it (this was added in later MMSIM versions to support the new capabilities in IC613 ADE XL), there's no access to it from the IC5141 Monte Carlo GUI.
    I guess you could run the simulation from the command line and modify the netlist - but that's probably also cumbersome.
    Or move to IC614 ;-)
  • lunren
    Thanks a lot Andrew, you help us Designer a lot. Let’s see when my company will move to IC614.
    Have a great day.
    Devin
