  3. How to implement this equation in VerilogA
  • Subscribers 128
  • Views 16463
princemahmmod
princemahmmod over 15 years ago
Anyone can you please help me how to write module the following equation in verilogA???
y = x/ (a * exp(-0.5 *((x-b)/c)^2)) +d
  • Quek
    Quek over 15 years ago
    Hi princemahmmod
    Would you please start a new thread for your question? By the way, there is a verilogA manual here:
    $MMSIMHOME/doc/veriaref/veriaref.pdf
    Best regards
    Quek
    I split this into a new thread. I agree with Quek, it doesn't make sense to mix different subjects in the same thread - it makes it much harder to follow.
    Here's an example:
    `include "disciplines.vams"
    module equation(y,x);
    output y;
    input x;
    electrical x,y;
    parameter real a=1.0;
    parameter real b=1.0;
    parameter real c=1.0;
    parameter real d=1.0;
    analog begin
    V(y) <+ V(x)/(a*exp(-0.5*pow((V(x)-b)/c,2)))+d;
    end
    endmodule
    Note that the parameter values I just made up - I was primarily ensuring the syntax was correct.
    I also posted this in response to your question on the Designer's Guide forums.
    I will split this off into a new thread when I get into the office. In general, it's best not to clutter existing threads with new topics.
