  3. Assura LVS JoinNets segmentation fault
  • Subscribers 129
  • Views 14899
simbamford
simbamford over 15 years ago
I've tried to add a "joinNets" specification to assura LVS. I've done this from Virtuoso Layout in Assura -> "RunAssura LVS" -> "Modify avCompareRules" -> "Network" ->joinNets. I've added the text:
joinNets("SN")
with the effect that it lists an extra avCompareRule which appears as:
:lay: joinNets("SN")
When I run it fails, with the following at the end of the log file:
Starting Nvn PreExtraction...
Starting /home/cdsmgr/Assura/tools/assura/bin/nvn /home/sim/Cadence/ASSURA_LVS/DFlipFlopSafeSetResetBufferedSqueezedChokedLowNClk2Out/DFlipFlopSafeSetResetBufferedSqueezedChokedLowNClk2Out.rsf -preExtract -exec1 -libdefs /home/sim/Cadence/lib.defs -cdslib /home/sim/Cadence/cds.lib
@(#)$CDS: nvn version av3.1:Production:dfII6.1.2:IC6.1.2.149 05/27/2008 17:23 (sfrh41) $
sub-version 317_USR2_HF7, integ signature 2008-05-27-1126
run on teodev1.iss.infn.it at Sun Apr 25 20:30:34 2010
Loading all available p-cell functions
AMS_DB set to cds
No mx check
ROD pcell code loaded
Finished /home/cdsmgr/Assura/tools/assura/bin/nvn
*WARNING* An error occurred during Nvn PreExtraction.
LVS preprocessing requires a successful run of Nvn.
Assura will now terminate.
*WARNING* /home/cdsmgr/Assura/tools/assura/bin/nvn exit with bad status
*WARNING* Segmentation Fault
*WARNING* Assura execution terminated
*WARNING* Bad exit from child process .. 0x100
*****  aveng terminated abnormally  *****
*WARNING* aveng exit with bad status
*WARNING* Status 256
*****  aveng fork terminated abnormally  *****
When I remove the specification it works fine, and this is repeatable, even after restarting cadence. Can anyone suggest what the problem might be?
Thanks very much,
 Sim Bamford
    Sim,
    It's a bug - it shouldn't seg fault. However, since the version you're using is no longer supported, your first avenue of investigation should be to try a supported version (e.g. ASSURA41). If the problem still occurs, please report to Customer Support.
  • simbamford
     Thanks very much.
    Sim
