  3. QRC vs. RCX
  • Subscribers 129
  • Views 15688
QRC vs. RCX
archive over 15 years ago
 Our foundry is using RCX for extraction (all the scripts are written for RCX) but we are using QRC for extraction. Are there any known issues in running an RCX setup/scripts on QRC?
 Best regards,
-Vijay
  • Quek
    Quek over 15 years ago
    Hi Vijay
    QRC is backwards compatible with RCX so there should not be any problems. In order to take full advantage of the higher extraction accuracy which QRC can provide, you should request for QRC techfiles from the foundry.
    Best regards
    Quek
    Hi Quek,
     Thank you very much. Is RCX offered by Cadence  currently?
     Best regards,
    -Vijay
  • Quek
    Hi Vijay
    Yes, rcx is still available from Assura package but we should no longer use it as it does not has any bug fixes or enhancements. If any problems are encountered while using rcx, the only solution will be to move to qrc.
    Best regards
    Quek
