  3. How to create personalized menu in virtuoso layout edit...
  • Replies 29
  • Subscribers 141
  • Views 44969
How to create personalized menu in virtuoso layout editor
AmitBiswas
AmitBiswas over 15 years ago
Hi, I have written few scripts in skill language. I want group all the scripts together into a single menu in virtuoso layout editor. Like in the layout editor window there are several menus at the top containing multiple functions, I want to create my personalized menu in the layout editor window. I also want to put that script in the .cdsinit file, so that when cadence will be started the menus will be loaded automatically in the layout editor window like the other menus. Thanks in advance, Amit
  • skillUser
    skillUser over 15 years ago
    Hi Zfeng,
    I will try to answer each of your questions.
    1) Yes, the benefit of modifying the list "in place" is that everything else remains as it was and should have the default behaviour.
    2) Again, yes, typically your utility functions would be defined in a file that is read by the .cdsinit startup SKILL file (or the function could be defined directly in the .cdsinit file, but generally it is cleaner to load these files).
    3) ?? Eh?  Start the session, test it.  For debugging purposes you might be able to add a printf statement at the end of the file to say that the something.menus file was loaded, you should see it in the CIW.  If you are modifying existing menus without adding or removing anything else then the menu may appear to look the same; perhaps this is your question?  Through SKILL you could check what the menu item callback was...
    4)  Sorry, I have not customized the ADE menus, so I will leave this to Andrew or someone else to reply to.
    5) Did you read the <instDir>/tools/dfII/etc/tools/menus/simui.menus file?  I believe it mentions a function sevAddMenuItemLists() that you might be able to use.  Again, I have not played with customizing the ADE menus, so someone else may be able to add some value here.
    Lawrence.
  • imagesensor123
    imagesensor123 over 15 years ago
    Hi Lawrence,
    Thanks for answering my questions, these day i often search on internet, and i find many guys confused to add user menus in analog artist, so i want to make this problem clearly, and others can refer to our posts. thanks again
    zfeng
  • SarathKumarG
    SarathKumarG over 15 years ago
                     When i executes your above code it shows error unbound var  _args .So i assign _args = geGetWindowCellView.it shows
    error  (hiMenu@0xf2b9088).plz let me know advice on this.
    Which code are you talking about? Is it the code in this link? If so, I can't see why it would complain about _args being unbound. Setting it to geGetWindowCellView() would be wrong, but it wouldn't cause that error. It doesn't really matter what it's assigned to, because it's not used (that's why I used the underscore convention to indicate that this is an argument that must be there, but isn't used inside the function).
    Please (not "plz" - there's no tax on characters here, so please use proper English words rather than instant messaging shorthand - see the Forum Guidelines) could you post the code you're actually using - that will make it clear an unambiguous. In fact you really should have started a new topic rather than carrying on an old one which is nearly a year old - also covered in the guidelines. But you've done it now...
  • jaleco
    jaleco over 13 years ago
    Andrew,
    How would we define a menu item that intentionally reloads the menu so we can test its functions, by reloading it from the interface, instead of closing the session each time?  The userMenuTrigger will not allow itself to be reloaded, preventing an update to the menu in-session.
    I am using something like the following in my attempt -
    [Menu_Item_Update = hiCreateMenuItem(?name 'Update ?itemtext "Update" ?callback "load("Menu.il") ); ]
    unless(!boundp('Menu)
      deRegUserTriggers("maskLayout" nil 'Menu)
    ); unless
    So if my Menu is already defined, it is not being re-registered. It may be getting updated, but is not reflected in the current session.  If I remove the "unless" construct, I get
    *Error* User menu trigger already registered for viewtype maskLayout.
    *Error* load: error while loading file - "Menu.il"
  • jaleco
    I see that the bang (!) character was misused, but regardless, the userMenuTrigger will not allow a reload of the menu in the same session.  Is there a way around this?
  • AmitBiswas
    AmitBiswas over 13 years ago
    Jaleco,
    You could update the manu without closing the session, all you need to do is before adding menu just check if that menu exists or not.
    If it exists , please remove from the window and add again.
     hiInsertBannerMenu(win  trPulldownMenu length(hiGetBannerMenus(win)))
    before the above command you need to remove the exixting menu if it exists.
    Amit
  • jaleco
    Hi Amit,
    thank you for your response.  I don't know how my post got attached to this thread - I was replying to the following example by Andrew Beckett and have created a new Post per his guidelines -
    /forums/p/17476/1245483.aspx#1245483
    Per his guidance I am avoiding the InsertBannerMenu construct in favor of the list passed as a MenuTrigger argument to deRegUserTriggers()....but not finding that it works for something that needs to be redefined in-session.
  • jaleco
    Ah, I see, there are 2 pages of thread and I was initially looking at the first page....
