  3. How to use spectre calculator to return x value of a given...
  • Replies 19
  • Subscribers 131
  • Views 52286
How to use spectre calculator to return x value of a given y? Thanks.
supermos
supermos over 14 years ago
Hello, I have a question about how to get x value for a given point of y in a waveform. I think the calculator should have this function, but I checked xval function, it doesn't work for me... Let me make my question more specific: for instance, if I sweep variable vinn, the circuit output is called vout, how we can find the vinn for vout = 2V? Thanks and best regards, ej
    Given that crossMethod is the internal function called within the cross function, and it is passed the same arguments as cross, it appears that the first argument to cross has been given as a scalar value rather than a waveform, so it's not surprising that it doesn't work.
  • fvillota
    fvillota over 11 years ago
    This is my calculator expresion:
    cross(IDC("/I0/icv0") 24e-6 1 "either" nil nil  )
  • skillUser
    skillUser over 11 years ago
    Isn't IDC() going to return a single scalar value rather than a waveform (as Andrew pointed out being the source of the problem for the cross function) ?  In other words, wouldn't the DC current be static, and therefore not cross any thresholds?
    Hope this helps,
    Lawrence.
    The IDC function returns a current from the dc operating point. So it is a single value - there's no variation and hence it makes no sense to use cross on it. Put another way, it will resolve to a number - there's no x axis, and only a single y value.
    ShawnLogan over 11 years ago
     Hi Francisco,
    I think Andrew's comment may be correct. Will not the function "IDC("/I0/icv0") return a scalar value? If you are trying to find a value from a DC analysis, perhaps you can use the value() function to interpolate between two values.
    Shawn
    If it's a dc sweep, then you should use IS() rather than IDC(), and you can find the x value for a given y with cross, or the y value for a given x using value().
  • fvillota
    Thanks to all of you, the right function for my mesaurement is IS rather than IDC.
     Best regards
  • vicky001
    vicky001 over 9 years ago
    Hi  I want the x-axis value of a waveform for a given y value.
    My measurement statement throws error saying "Expression evaluates to nil". Need your expert help in understanding where am going wrong.
    Measurement statement is :
    cross(clip(dB20(VF("/vout")) 10 1G ) ymax(clip(dB20(VF("/vout")) 10 1G )) 1 "rising" nil nil )
    Basically I am trying to get the X-axis(frequency value) of the clipped output waveform where the wave has the maximum value. The "ymax" expression gives me a correct number.
    My virtuoso version is IC6.1.6.500.7
    There's a CCR to fix this in an IC617 ISR (it may have been fixed now) which is to allow cross to return a value that it doesn't actually cross but exactly reaches. However, as I pointed out in that CCR, there's a much cleaner solution that already works (forever) and is simpler. Use xmax instead of ymax. That already gives you the x-value where the maximum occurs:
    xmax(clip(dB20(VF("/vout")) 10 1G ))
