  3. Export data to CSV format
  • Replies 21
  • Subscribers 137
  • Views 69400
CPete
CPete over 15 years ago
I'm trying to export I-V curves from the Spectre Simulator into CSV files. However, the save/save as menus only allow for saving the data in a figure-format file or as a PNG/TIFF/Image File. Is there a mode, command, or code sequence that would allow me to export my data to CSV or other data formats readable in Excel? Thank you for your assistance.
    Andrew Beckett over 8 years ago in reply to salar1991
    salar1991 said:
    my version is IC6.1.4.485
    Next time I suggest you read the forum guidelines before you post. Failing to mention that you are using an 8 year old version of the tool (I think it's about 8 years - I don't have access to that precise version - the closest I could find was the first ISR (hotfix) which came out in February 2010), plus posting on the end of a 7 year old thread are both things it tells you not to do in the guidelines.
    If you'd mentioned the version, it might have been possible to tell you why it didn't work. The waveform tool between then and now is totally different.
    I'm not sure there's a good reason to be using such an ancient version of the tools.
