  3. Internal error with topology.c
  • Replies 12
  • Views 22358
CPete
CPete over 15 years ago
 When I try to run a Spectre dc and trans simulation with my 8-bit-adder circuit, have an internal error stopping the simulation.  I get the following messages in the spectre log window:
1) the usual "unable to compile ahdlcmi module library" message (which has not stopped my simulations in the past),
2) a warning from spectre during initial setup about having PMOS and NMOS from the driver circuit running at 1 A/exceeding imelt = 10 mA (the test driver/load circuit provided by our course instructor)
3) "Internal error found in spectre during topology check, during initial setup." --> "Assertion failed in file 'topology.c' at line 1008"
Any ideas how to interpret error #3??  I've done the Virtuoso save and check with no error for the 8-bit-adder or any of the lower schematics in the hierarchy.
To explain how I'm implementing an 8-bit-adder:  The design is four 2-bit-adders linked together.  Each 2-bit-adder is made of 2 individual adders.  Individual adders have Carry Out implemented with CMOS and Sum implemented with pass-logic transistor gates.
Thank you for your time.
  • Conhas
    Conhas over 10 years ago
    Dear Tawna,
    Thank you for your response.
    Curently I am using the following -
        Setup Cadence/IC_6.1.6
        Setup Cadence/PVS_14.1 for IC_6.1.6
        Setup Cadence/Assura_4.1.4 for IC_6.1.6
        Setup Cadence/MMSIM_13.11 for IC_6.1.6
        Setup Cadence/INCISIVE_14.10
    And still I am getitng the assertion errors.
    Can you please help with the same?
    I found a CCR (1355410) with exactly that error which was fixed in MMSIM14.1 ISR4. The version you've selected is at least a couple of years old, so I'd definitely suggest trying to move to something that is more recent than MMSIM14.1 ISR4.
    We've certainly seen this failing when using models from Global Foundries.
