  3. spectre - saving by specific subcircuit
  • Replies 11
  • Subscribers 136
  • Views 16778
swdesigner
swdesigner over 15 years ago
Is it possible to tell spectre to save all nodes or terminal currents within a certain subckt? It's trivial in Hspice, you could do
save all Xtop.Xsub.*
I believe there's even a way to use the wildcards to get it to only do the top-level within that subcircuit, but I don't recall it..
Any ideas? How would it be done through the ADE, without messing with the netlist?
  • Marc Heise
    Marc Heise over 15 years ago +1
    Hi, a quick >spectre -h save will reveal that it is trivial in spectre as well: Examples of pattern matching: save x*.*1 depth=3 saves the voltages of all nodes from level 2 to level 3 whose name starts…
  • TFTIC
    TFTIC over 11 years ago
    Hi, I would like to know how I could save specific extracted net names by using wildcards. I ./runSimulation through terminal and I cant find the correspondence between the extracted nets and the nets in the schematic. I use Calibre (Mentor) and the flow doesn't look straightforward to me. Is there any specific flow to find easily the correspondence and later on perform the simulation through terminal by saving the nodes of interest?
