  3. How to know a special run montecarlo simulation varianc...
  • Replies 12
  • Subscribers 133
  • Views 20762
How to know a special run montecarlo simulation variance
loon
loon over 14 years ago
I have a question about the montecarlo simulation.
I run a  100 runs montecarlo simulation, and find out that the run No. 80 has some
bad simulation results. So I just run No. 80 montecarlo simulation and try to see
why this run has problem. But I can not see the DC voltage, operating points,  and
component real parameters. How I can obtain these kinds of results? Thanks!
  • panchkapunch
    panchkapunch over 14 years ago
    Thanks...so, is there a way to ensure both process and mismatch parameters remain the same?
    Yes, don't change the topology of the circuit! As I said, process will always remain the same for a given run number and seed number, whereas mismatch will depend on the order of the devices in the circuit - because it has to produce random variations per subckt instance. If there are differences in the circuit, it will inevitably produce differences in the mismatch. If you're only changing a design variable, then you're safe.
