  3. Simulation->Stop during ams simulation causes digital waveforms...
  • Subscribers 129
  • Views 1689
Simulation->Stop during ams simulation causes digital waveforms to not be plotted
malik b
malik b over 14 years ago
I am using the ams simulator, and find that if I do Simulation->Stop, any
digital waveforms set up in the Outputs pane are not plotted.
I have no problem with plots of digital signals when run to completion, or if the
plot outputs icon is pressed during a simulation. The issue only occurs if the simuation is
manually stopped.
If I add the -vcd option in my probe command
probe -create -vcd -emtyok -all -depth all -domain digital
and translate the output file ncsim.vcd in sst2 file to watch with simvision, it's ok but I have two output files to manage.
Is there any other simple solution ?
Regards
icfb -W
sub-version 5.10.41.500.6.148
ncsim -W
ncsim(64): 10.20-s076
simvision -W
simvision(64): 10.20-s076
aps -W
sub-version  10.1.1.128.isr9
  • Roel vE
    Roel vE over 12 years ago
    Not much help, but same here.
     Regards.
    I think this might have been fixed (but in IC615) - I can't remember. Anyway, if it's still an issue there in IC615, please report it to customer support (sorry for the rather vague reply, but I'm swamped out at the moment...)
