  3. How to combine two plots y1=f(v1) & y2=f(v2)
  • Replies 11
  • Subscribers 132
  • Views 10158
SUEE
SUEE over 14 years ago
Hi all,
In ADE plot using AWD, how to combine two plots y1=f(V1) & y2=f(V2)
For y1=f(V1(t)), I could plot V1 along the x-axis and y1 along the y-axis
Similarly for y2=f(V2(t)), I could plot y2 (on the y-axis) versus V2 (along the x-axis)
Because V1(t) is not equal to V2(t) so that I can not plot both y1 & y2 respect to either V1 or V2.
However, I do need to overlap the y1=f(V1) and y2=f(V2) on the same plot.
What can I do?
Thank you very much !!
    The function takes the buffer plus the first entry on the stack. So for example, if you use the "VT" button in the calculator and click on the net that is to be the x-axis signal, and then the net that is to be the y-axis signal, and then click on the new special function - it will build the expression.
    I don't know why you were getting all those errors when loading the file. I cut and pasted it from the web site (into a file) yesterday and then used:
    load("abChangeXAxis.il")
    And then it worked fine. Did that work? If so, how were you loading the file in the case that it didn't work?
