  3. make it clearly beta and betaeff
  • Replies 13
  • Views 42397
imagesensor123
imagesensor123 over 14 years ago
    these days i am doing some circuit simulation, and i got confused by beta and betaeff? according to the simple hand calculation equation id=1/2uCoxW/L(Vgs-Vth)^2 or id=1/2beta(Vgs-Vth)^2  or the others. and after simultion, i use the result->print->operation point and i found a betaeff parameter, i think it shold be same with beta, but after calculation id, i found the id(betaeff) is just a half of the id(beta), and how do you calculate the drain current id in saturation region?
  • Quek
    Quek over 14 years ago
    Hi Zfeng
    Actually there are really too many reasons why your hand calculated results are different from simulation results.
    a. You might have calculated wrongly
    b. Bug with simulator
    c. For advanced process nodes, you might have simplified too many things
    If there is really a need to clarify this, I think it would be good for you to file a service request to your local Cadence support.
    Best regards
    Quek
  • imagesensor123
    Hi Quek,
        thanks, i will check it carefully, and i will generate a request if necessary. any way, thanks a lot for your help.
    regards,
    zfeng
  • EthanRFIC
    EthanRFIC over 12 years ago
     I think for nowadays, you may check "Gm/Id" design methodology, which is much MORE accurate for your design, and just get rid of the "squared law equation". I design RFIC circuit using this method, all the design procedure is calculated in Matlab script, even "no need to simulate in spice", I mean, when I click the Matlab, I get the W/L for all the transistors, then simulate it in cadence ----  everything mathched well with my theoretical analysis.
     If you need more information, you can google "Gm/Id" method on IEEE, there are a lot of papers talking about it. Good luck!
