  3. Area calculation from layout in cadence 6.1.4
  • Replies 14
  • Subscribers 139
  • Views 33651
kpkp
kpkp over 14 years ago
Hi all,
I have generated a layout in cadence virtuoso layout editor...but dont knw how to calculate the area of layout? please anybody can help me?
Thanx in advance...
  • seaurchin
    seaurchin over 11 years ago
    Thank you for your response. I have copied and pasted your code below to a .il file and load it in my .cdsinit. However, I receive the following error when I selected the geometries in my layout and typed "ABarea()" in my CIW:
    ABarea()
    *Error* ABarea: too few arguments (1 expected, 0 given) - nil
    What argument is it expecting? I am sure I am missing something but not sure what to try.
    Thank you for your help in advance,
    Helen
    /* CCSflattenAndMerge.il
    Language SKILL
    Date Apr 17, 2007
    Modified Apr 20, 2007
    Function to flatten and merge a particular layer into a
    destination (typically scratch) cellView:
    src=geOpenCellView()
    dst=dbOpenCellViewByType(src~>libName src~>cellName "flattened"
    "maskLayout" "w")
    CCSflattenAndMerge(src dst '("M1" "drawing"))
    Or
    CCSflattenedArea(src dst '("M1" "drawing"))
    (this will flatten and merge, and then calculate the area of the shapes).
    Uses ABarea.il to calculate the area of the shapes.
    This code handles simple mosaics - complex mosaics (as produced by the
    end-of-lifed Structure Compiler tool are not handled). The mosaic
    handling should work in both OpenAccess and CDB. Also, vias are
    handled in OpenAccess.
    SCCS Info: @(#) CCSflattenAndMerge.il 04/20/07.12:52:45 1.2
    * DISCLAIMER: The following code is provided for Cadence customers to use at *
    * their own risk. The code may require modification to satisfy the *
    * requirements of any user. The code and any modifications to the code may *
    * not be compatible with current or future versions of Cadence products. *
    * THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING WITHOUT *
    * LIMITATION ANY EXPRESS WARRANTIES OR IMPLIED WARRANTIES OF MERCHANTABILITY *
    * OR FITNESS FOR A PARTICULAR USE. *
    * (CCSflattenAndMerge srcCv dstCv lpp @optional *
    * (transform list(0:0 "R0" 1)) *
    * (top t)) *
    * Traverse a hierarchy, copying and transforming shapes on a *
    * specified layer purpose pair into a flat destination *
    * cellView. At the end, merge all the shapes on that lpp. The *
    * transform and top arguments are normally only passed when *
    * this function is called recursively from within itself. *
    (defun CCSflattenAndMerge (srcCv dstCv lpp @optional
    (top t))
    (foreach shape
    (dbGetq
    (car (exists LPP (dbGetq srcCv lpps)
    (and
    (equal (dbGetq LPP layerName) (car lpp))
    (equal (dbGetq LPP purpose) (cadr lpp)))))
    shapes)
    (dbCopyFig shape dstCv transform)
    (foreach inst (dbGetq srcCv instances)
    (when (equal (dbGetq inst objType) "inst")
    (CCSflattenAndMerge (dbGetq inst master) dstCv
    lpp
    (dbConcatTransform
    (dbGetq inst transform)
    transform)
    nil)
    (foreach via (dbGetq srcCv vias)
    (CCSflattenAndMerge (dbGetq (dbGetq via viaHeader) master) dstCv
    lpp
    (dbConcatTransform
    (list (dbGetq via origin) (dbGetq via orient) 1)
    transform)
    nil
    (foreach mosaic (dbGetq srcCv mosaics)
    (if (equal (dbGetq mosaic mosaicType) "simple")
    (let (master orient xy isOA newTransform mosaicTransform)
    ; OpenAccess stores mosaics differently - in CDB,
    ; the individual instances are rotated - in OA, the
    ; whole mosaic is rotated. So need to detect database
    ; type used, and adjust transformations accordingly
    (setq isOA (and (isCallable 'dbGetDatabaseType)
    (equal (dbGetDatabaseType) "OpenAccess")))
    (setq master
    (dbGetq (car (dbGetq mosaic instanceList)) master))
    (setq orient (car (dbGetq mosaic tileArray)))
    ; If OA, the transformation of the whole mosaic
    ; is calculated - by shifting to the origin, rotating,
    ; and then shifting back
    (when isOA
    (setq mosaicTransform
    (dbConcatTransform
    (dbConcatTransform
    (list
    (mapcar 'minus (dbGetq mosaic xy)) "R0" 1)
    (list (list 0 0) orient 1))
    (list (dbGetq mosaic xy) "R0" 1))
    ; Iterate over the rows and columns, flattening each
    ; sub-instance in the simple mosaic
    (for row 0 (sub1 (dbGetq mosaic rows))
    (for col 0 (sub1 (dbGetq mosaic columns))
    (setq xy
    (list
    (plus (xCoord (dbGetq mosaic xy))
    (times col (dbGetq mosaic uX)))
    (plus (yCoord (dbGetq mosaic xy))
    (times row (dbGetq mosaic uY)))
    ; Compute the transformation of the sub-instance
    ; Done differently for OA and CDB
    (setq newTransform
    (if isOA
    (dbConcatTransform
    (dbConcatTransform
    (list xy "R0" 1)
    mosaicTransform)
    transform)
    (dbConcatTransform
    (list xy orient 1)
    transform)
    ; Call CCSflattenAndMerge recursively
    (CCSflattenAndMerge master dstCv lpp
    newTransform
    nil)
    ) ; for col
    ) ; for row
    ) ; let
    (warn "Complex mosaic %s in %s/%s/%s ignored\n"
    (dbGetq mosaic name)
    (dbGetq srcCv libName)
    (dbGetq srcCv cellName)
    (dbGetq srcCv viewName)
    ; Using leMergeShapes is slow, so use dbLayerOr to do the merging,
    ; and then delete the original shapes
    (when top
    (let (origShapes)
    (setq origShapes
    (dbGetq (car (exists LPP (dbGetq dstCv lpps)
    (and
    shapes))
    (dbLayerOr dstCv lpp origShapes)
    (foreach shape origShapes (dbDeleteObject shape))
    t
    * (ABarea object) *
    * Calculate the area of an object. *
    * Currently only works with polygons and rectangles. *
    (procedure (ABarea object)
    (let (sum crd lastPt firstPt crdList area corners ll ur dx dy objType)
    (setq objType (dbGetq object objType))
    (if (equal objType "polygon")
    (progn
    (setq crdList (dbGetq object points))
    (setq sum 0)
    (setq firstPt (setq lastPt (car crdList)))
    (setq crdList (cdr crdList))
    (foreach crd crdList
    (setq dx (difference (xCoord crd) (xCoord lastPt)))
    (setq sum (plus sum
    (times dx (plus
    (yCoord crd)
    (yCoord lastPt)))))
    (setq lastPt crd))
    (setq sum (plus sum
    (times (difference (xCoord firstPt)
    (xCoord lastPt))
    (plus (yCoord firstPt) (yCoord lastPt)))))
    (setq area (times 0.5 (abs sum))))
    (when (equal objType "rect")
    (setq corners (dbGetq object bBox))
    (setq ll (car corners))
    (setq ur (cadr corners))
    (setq dx (difference (xCoord ll) (xCoord ur)))
    (setq dy (difference (yCoord ll) (yCoord ur)))
    (setq area (abs (times dx dy))))
    area))
    * (CCSflattenedArea srcCv dstCv lpp) *
    * Given an empty destination (scratch) cellView, flatten and merge *
    * all shapes on the given layer purpose pair, and then return the area. *
    (defun CCSflattenedArea (srcCv dstCv lpp)
    (let ((area 0.0))
    (CCSflattenAndMerge srcCv dstCv lpp)
    (foreach shape
    (and
    shapes)
    (setq area (plus area (or (ABarea shape) 0.0)))
    area
  • acom
    acom over 11 years ago
    Hello ,
    I have taken a glance at the script.I think the function you should use in your CIW should like below rather than ABarea() at this time.:)
    				      "maskLayout" "w")
    Or
    In addition, I'm not sure it's quite what you want anyway, because the shapes in the mark net information (copied to another cellView) could be on multiple layers. You probably don't really need to use CCSflattenedArea at all because the data is already flat - you might be better off doing this (with the window which contains the mark net copied shapes in as the current window):
    cv=geGetEditCellView()
    newShapes=dbLayerOr(cv list("y0" "drawing") cv~>shapes)
    area=0.0
    foreach(shape newShapes
      area=area+ABarea(shape)
      dbDeleteObject(shape)
    printf("Total area is %g\n" area)
    (note, this is completely untested, but I think it should work). The dbLayerOr is producing a merged representation of all the shapes onto a temporary output layer, and then the code iterates over all the new shapes adding up the areas by calling ABarea on each shape. Since the y0 shapes are just working shapes, it deletes them as it works through them all.
  • seaurchin
    Hi guys,
    Thank you very much for your help.
    Andrew's code works perfectly! It calculates the area of my layout in the opened cell view. And thank you for explaining what the code does to me. It really helps.
    Thank you and regards,
    Helen
