  3. "capgen" error in Assura QRC (RCX)
  • Replies 24
  • Subscribers 136
  • Views 14056
bjbit
bjbit over 14 years ago
Hi all,
I work with the technology of IBM CMOS7RF on Cadence 5.1 (IC5141). Currently I am trying to extract parameters for a self-customized inductor.  By setting "ind" model in schemetic as a blackbox and ignoring mismatches, I go through LVS. Now an error happens in QRC as below.
*WARNING* at "capgen": x-tile size is not floating point number
*ERROR* at "capgen": capgen job quit due to process file errors.
quitting.
 -blocking coupled5_shield1:0.02,M1,M2,M3,M4,M5 -blocking coupled5_shield2:0.02,M2,M3,M4,M5 -blocking coupled5_shield3:0.02,M3,M4,M5 -blocking coupled5_shield4:0.02,M4,M5 -blocking coupled4_shield1:0.02,M1,M2,M3,M4 -blocking coupled4_shield2:0.02,M2,M3,M4 -blocking coupled4_shield3:0.02,M3,M4 -blocking coupled3_shield1:0.02,M1,M2,M3 -blocking coupled3_shield2:0.02,M2,M3 -blocking coupled2_shield1:0.02,M1,M2 -blocking singleEndA_shieldT:0.02,MT,ML -blocking singleEndA_shield5:0.02,M5,MT,ML -blocking singleEndA_shield4:0.02,M4,M5,MT,ML -blocking singleEndA_shield3:0.02,M3,M4,M5,MT,ML -blocking singleEndA_shield2:0.02,M2,M3,M4,M5,MT,ML -blocking singleEndA_shield1:0.02,M1,M2,M3,M4,M5,MT,ML -res_blocking singleEndA_shieldT:0.02,ml -res_blocking singleEndA_shield5:0.02,ml -res_blocking singleEndA_shield4:0.02,ml -res_blocking singleEndA_shield3:0.02,ml -res_blocking singleEndA_shield2:0.02,ml -res_blocking singleEndA_shield1:0.02,ml -blocking singleEndT_shield1:0.02,M1,M2,M3,M4,M5,MT -blocking singleEndT_shield2:0.02,M2,M3,M4,M5,MT -blocking singleEndT_shield3:0.02,M3,M4,M5,MT -blocking singleEndT_shield4:0.02,M4,M5,MT -blocking singleEndT_shield5:0.02,M5,MT -blocking singleEnd5_shield1:0.02,M1,M2,M3,M4,M5 -blocking singleEnd5_shield2:0.02,M2,M3,M4,M5 -blocking singleEnd5_shield3:0.02,M3,M4,M5 -blocking singleEnd5_shield4:0.02,M4,M5 -blocking singleEnd4_shield1:0.02,M1,M2,M3,M4 -blocking singleEnd4_shield2:0.02,M2,M3,M4 -blocking singleEnd4_shield3:0.02,M3,M4 -blocking singleEnd3_shield1:0.02,M1,M2,M3 -blocking singleEnd3_shield2:0.02,M2,M3 -blocking singleEnd2_shield1:0.02,M1,M2 -blocking ml_transmission,sti,ML -blocking symind3_mlml_m1,sti,M1,MT,ML -blocking symind2_mlml_m1,sti,M1,MT,ML -blocking ind2_mtml_m1,sti,M1,MT,ML -res_blocking symind3_mlml_m1,mt_resistive,ml -res_blocking symind2_mlml_m1,mt_resistive,ml -res_blocking ind2_mtml_m1,mt_resistive,ml -blocking symind3_mlml_bb,sti,MT,ML -blocking symind2_mlml_bb,sti,MT,ML -blocking ind2_mtml_bb,sti,MT,ML -res_blocking symind3_mlml_bb,mt_resistive,ml -res_blocking symind2_mlml_bb,mt_resistive,ml -res_blocking ind2_mtml_bb,mt_resistive,ml -blocking bondPad_PC:5.28,sti,PC,ML -res_blocking bondPad_PC:5.28,ml -blocking bondPad_BB:5.28,sti,ML -res_blocking bondPad_BB,ml /home/zheng072/zy_senser/inductor_test1
*WARNING* Bad return status from RCX script generator. 0x100
I cannot figure out what's wrong with "process file". I have installed Assura QRC package exactly as the document states. Any advices are appreciated.
Thanks.
  • Quek
    Quek over 14 years ago
    Hi bjbit
    My guess is that you are using redhat enterprise 4.x. You will need redhat enterprise 5.5 and above in order to use PVE package. : )  If it is not possible to find a machine with RHEL5.5 and above, you can also also use the slightly older EXT10.1.2 package. It should also resolve your problem. The history of QRC is as follows:
    a. Named as "rcx" and comes from Assura package
    b. Combined with cell level extractor and renamed as "QRC". Comes from EXT package.
    c. Packaged together with PVS in PVE package.
    Best regards
    Quek
  • bjbit
    Hi Quek,
    Thanks for the advices. I will ask the manager to have a check.
    bjbit
  • Jonjohn
    Jonjohn over 14 years ago
    bjbit said:
    QRC menu, "Loading QRC menu..." is shown under it, and a warning of "RCX UI is already loaded" is given in CIW
    Sorry for my English.
    I have the same problem. I Upgrade EXT91 to EXT101 and now The QRC menu only give me  "Loading QRC menu..." and I ha ve the same warning about RCX UI.
    Does anyone has an idea?
    Thanks in advance
  • bjbit
    Hi Johjohn,
    As Quek advised, I have fixed this problem on PVE11 by using the newer version of Linux system. I am not sure about the compatibility of EXT10, but did EXT9 work for you? If so, probably you are having the same Linux issue. I guess you may try on another machine with newer version OS, and see what's going on. Anyway, I believe Quek can provide further advices.
    bjbit
  • Jonjohn
     Hi bjbit.
    I'm working on Fedora 15. With EXT9, it works. But not with EXT10. The two install have the same configuration...
    I don't know why.
  • Quek
    Hi bjbit
    Thanks. : )
    Hi Jon
    Would you please try upgrading to the latest version of Assura (41USR2_HF14) and latest version of EXT10.1 (10.1.3)? I think the earlier versions of EXT10.1 has this problem.
    Best regards
    Quek
  • Jonjohn
    Hi Quek,
    Thanks for your reply.
    I already made all the update. I'm well running Assura  41USR2_HF14 and the latest version of EXT10.1.3. But the problem still exist.
    If I running virtuoso layout whithout ASSURAHOME environmental variable configured, and if I click the qrc menu I have this message:
      *WARNING* QRC_HOME environmental variable is set but UI can't locate correct QRC installation. p, li { white-space: pre-wra
    In order to run UI in QRC compatibility mode you need to have QRC executables in your $PATH and QRC version should be 8.1 or greater.
    Check your QRC installation and environmental settings.
    And my environmental is configure like this:
    setenv QRC_HOME /softs/cadence/EXT101
    setenv PATH $QRC_HOME/bin:$PATH
    setenv PATH $QRC_HOME/tools/bin:$QRC_HOME/tools/extraction/bin:$PATH
    If I run  $QRC_HOME/tools/bin/qrc , it return nothing. But whith EXT9 it works with the same configuration.
     Best regards
    Jonjohn
  • Quek
    Hi Jonjohn
    Would you get the path to the qrc executable if you enter the following in a terminal window?
    terminal>which qrc
    How about this?
    terminal>qrc -version
    Best regards
    Quek
  • Jonjohn
    Hi Quek,
     which qrc return: /softs/cadence/EXT101/tools/bin/qrc
    In fact I solved a part of the problem if I set OA_HOME to "/softs/cadence/IC614/share/oa", qrc don't work : the command "qrc -version" return nothing.
    But if I don't set the OA_HOME variable, it works...
    If I set OA_HOME to  "$QRC_HOME/share/oa, I can't run virtuoso. I have this error:
     /softs/cadence/IC614/tools/dfII/bin/64bit/virtuoso: /softs/cadence/IC614/tools/lib/64bit/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /softs/cadence/EXT101/share/oa/lib/linux_rhel40_gcc44x_64/opt/liboaPlugIn.so)
    /softs/cadence/IC614/tools/dfII/bin/64bit/virtuoso: /softs/cadence/IC614/tools/lib/64bit/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by /softs/cadence/EXT101/share/oa/lib/linux_rhel40_gcc44x_64/opt/liboaCommon.so)
    Any idea?
     Best regards
    Don't set OA_HOME. You should not have to - and if you do, you end up with these kind of potential compatibility headaches.
    If you don't set OA_HOME, each build can use the OA version it was shipped with, which is the right thing to do since that's what has been tested...
