  3. Import some particular shape in to Cadence layout L
  • Replies 23
  • Subscribers 137
  • Views 26676
engine2011
engine2011 over 14 years ago
 Hi everyone,
 I want to use standard technology to fabricate a device which is basically a circle shape realized with the toppest level metal layer. Because the process resolution is 0.01um, the smooth brim of circle is not acceptable and will introduce some class a DRC errors.
 Now I am making the brim of circle replaced by 90 degree polygon to solve these errors. The problem is, if I want to make it a good approximation to a circle, the polygon will be very complex. I can use Matlab to generate this shape without much effort, however, it will be very complex to draw it manually in Cadence. Does cadence have some function to import the shape data from Matlab?
 Thanks!
EF
  • engine2011
    engine2011 over 11 years ago
    Hello Andrew, thanks for giving me this helpful solution two years ago. I may bother you a little bit more this time because when I tried to re-do this again I found I may miss something. When I did load("abXmpToLayout.ils") it tells me *Error* load: can't access file - "abXmpToLayout.ils" <<< Stack Trace >>>. Could you tell me what's that error is?
    It's telling you that it can't access the file! First of all, did you get the file name correct - the original file was called abXpmToLayout.ils, not abXmp... Secondly if you don't give a pathname component (no directory) then it will look for the file in the SKILL path as returned by getSkillPath() and if that doesn't include "." then it won't look in the working directory. Regards, Andrew
  • engine2011
    I figured it out, thanks a lot!
