  3. monte-carlo simulation running one seed
  • Replies 12
  • Views 31474
frogconsultant
frogconsultant over 14 years ago
Hi All,
I am using 6.1.5 environment and I have ran a monte-carlo simulation over 100 runs yesterday and I load back my results. Some runs have failed and I wish to see more data on these particulars seeds. I went to the monte-carlo options and choose the specific seed number and re-run only this one with monte-carlo.
As a result, I do not have the correct seed environment and so the same results.
How could I re-run a specific seed number from a monte-carlo run with all data such dc voltage, dc operating point, waveforms specified, ...?
Thanks in advance for your help,
Fabian
    Andrew Beckett over 14 years ago +2
    Hi Fabian, The best way is not to mess around with the "seed". If the seed was not set, it defaults to 12345. It's the start run number that you'd want to use, rather than the seed. The seed alters the…
  • Frank Wiedmann
    Frank Wiedmann over 13 years ago
    In the meantime, this problem has been submitted as CCR 1136784 (enhancement request). Anyone who also has a problem with the behavior described in this thread should consider asking Cadence support to file a duplicate of this CCR on his behalf. If more people are asking for this enhancement, it is more likely to be implemented soon.
  • Frank Wiedmann
    Frank Wiedmann over 12 years ago
    Statistical corners based on parameter values (and not just the seed value) are now available in IC6.1.6 ISR6. You can find more details at /blogs/cic/archive/2014/03/10/fast-yield-analysis-and-statistical-corners.aspx and http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:DocumentViewer;src=pubs;q=/adexl/adexl6.1.6/adexlMC.html#_axlStatisticalCornerChoice.
