  3. APS, Multi-threading, High-Performance Simulation...
  • Replies 11
  • Subscribers 136
  • Views 36661
aditeman
aditeman over 14 years ago
Andrew,
I am a bit confused with all of the high performance simulation options in ADE-XL/GXL.
I am using IC 6.1.5.506 with  MMSIM 10.11.200
On ADE I have:
  1. "Options->Job Setup->Max Jobs"
   2.  "Options->Run Options-> Run In"
  3.  "High-Performance Simulation->Mode, Multithreading options, Affinity"
  4. "Options->Analog->Multithreading Options"
Maybe others...
What is the up to date way to run my simulations as fast as possible?
The main reason I'm asking is that I've had some problems when setting things such as APS + Max Jobs=8. For example, I've had these settings and sent a small simulation with a few corners and after waiting 10 minutes it still hadn't started. In general, it seems to take minutes until simulations start running sometimes (and then they run very fast).
Any suggestions/explanations?
ADi
  • lartola
    lartola over 8 years ago
    yes I'm using MMSIM141. But I need to use IC5141 for PDK compatibility.
    Thanks for your aid.
    Regards
    laurent
