  3. Ocean/Calculator expressions and their units
  • Replies 12
  • Subscribers 136
  • Views 17741
MicheleA
MicheleA over 14 years ago
Hi all,
I know it's not advised to put more than one questions per post, however I hope I'll structure this such that there won't be no confusion.
Main Topic
I am defining some expressions I would like to assess in my designs. To this end, I use the calculator in conjunction with some "ocean" script...Actually I just write expressions and define variables on a plain text file, but the idea is to expand on that with plotting functions and maybe output to file.
So let's say I have an AC sim. I then define some curves as follows:
twoPi = 44.0/7.0
vtank = VF("/tank_pos")-VF("/tank_neg")
itank = IF("/Vgen/MINUS")
icap = IF("/Cprobe/PLUS")
icapfix = IF("/Cfprobe/PLUS")
iind = IF("/Lprobe/PLUS")
runfreq = xval(vtank)
Ytank = itank/vtank
Zcap = vtank/icap
Zcapfix = vtank/icapfix
Zind = vtank/iind
cap = 1/(-twoPi*runfreq*imag(Zcap))
Now, it all works good if I copy/paste these definitions in the CIW, then ask --> plot(cap)
The issue I have with this is that now the Y-axis shows "freq" units...
cap value in femtohertz?
I observed that runfreq, defined as xval, is still correct. But if I do 1/runfreq, what I get is something with units of 1/(1/Hz), instead of s.
So probably here's where it loses it. Anyways, I see two possibilities here:
  1. I am doing it wrong
  2. I am doing it right
If 1 holds, then what's the right approach for something like this?
If 2 holds, do I have a way of "forcing" units onto expressions?
--------------------------------------------------------------------------------------------- END -----------------------------------------------------------------------------------------
Side Topic
 I find it more comfortable to write my expressions in the text editor rather than inputting them in the output definition box of ADE or ADE-XL. Is there a way of having the environment read my definitions as a file, and then just output the final expressions? In the (simple) case at hand, I would have defined all expressions as above, and plot them either from the CIW or directly from the file...
Thanks for your help!!
 Michele
  • MicheleA
    Oh, so you're human Andrew! Given the speed/quality of your support, I was thinking Cadence developed some super-human supporter there!
    It works perfeclty, really thanks a lot for your help!
    Michele
  • XinjiePI
    XinjiePI over 12 years ago
    Could I ask one simple question about ADE XL calculator.
    I use IC615 and MMSIM 7.1 for simulation and calculator can get expression from schematic when I click wire or spot.
    It works well but somehow sometimes when I ran simulations serveral times and it seems can not get expression if I change the wire. It looks like "un-link" between schematic and ADE calculator. I can only make it working by re-invoke icfb. Could I ask your advise for any other method to "rebuild link" between calculator and schematic?
    Xinjie Wang
