  3. Keyboard shortcut for running simulation in ADE GXL?
  • Replies 13
  • Views 27977
rickyuexu
rickyuexu over 13 years ago
Is there any keyboard shortcut for running simulation in ADE GXL/XL/L?
I really don't want to move the mouse to hit that green button every time I run the simulation, especially when Cadence is not running on my local workstation.
Thanks!
  • sjwprc
    sjwprc over 8 years ago in reply to Andrew Beckett
    As you comment, I remove the 1st sentence about prefix, use only : hiSetBindKey("Schematics" "<Key>F5" "sevNetlistAndRun(sevSession(hiGetCurrentWindow()))").
    And I can ensure the schematic window is linked to ADE L . But when I use F5, nothing happen, even no warning pop-up. Do I use the command same as you ?
    Regards
    Andrew Beckett over 8 years ago in reply to sjwprc
    Well, that works for me. What happens if you do:
    hiSetBindKey("Schematics" "<Key>F5" "println(987654321)")
    Does it print the number in the CIW when you hit F5 in the schematic window?
  • sjwprc
        I think I find the reason why F5 not work. Because I also use F5 as bindkey for adexl. Seems there is contradiction between them. As soon as change it to another icon, sim runs well.
        Thanks for your help !
    Regards
