  3. where can I find the 'rcut' variable to change it? Cadence...
  • Subscribers 129
  • Views 6101
where can I find the 'rcut' variable to change it? Cadence 6.15.509
zcam
zcam over 13 years ago
I have a customized electronic model  for my circuit input. This model contents some resistor larger than 'rcut' which is now equals to 1e12 Ohm in my cadence setup.
I guess this limit can be changed. But I couldn't find where to change? Any body has expirences on this?
Kangqiao
    I'm assuming you're talking about spectre? If so, this is probably "rcut" as described in "spectre -h options". The default is infinity, except for bsource resistors. Given that  you've not told us much about how this is affecting you, or what the model looks like, I suggest you contact customer support so you can provide some details (if you can't provide them here). There's not normally much benefit in having resistors larger than 1e12 because the default gmin is 1e12 too and so the chances of the resistance having any effect in the solution are pretty small.
  • zcam
    Thank Andrew.
    I found the rcut option in spectre reference manual.  And tested with for example add something in the option for each analysis:
    rcut=1e14
    which should be large enough for our model. But as you said, the result has nothing changed.
    Kangqiao
