  3. Minimum Value Function Exists in Waveform calculator?
  • Subscribers 129
  • Views 16264
canbaltaci
canbaltaci over 13 years ago
I am using ADE, IC5141. I perform a DC simulation and I defined two different scalar outputs (let's say O_1 and O_2). Now, I would like to define a new scalar output O_3 which is the minimum value among the scalar outputs O_1 and O_2. Is there a simple special function to define the output O_3? If there is not how can I define such an output?
 Best regards,
Can
    In IC615 (and IC614) you can directly reference the name of the output as a variable. In IC5141 however, you'd have to make the output have an assignment. So for example, rather than having:
    O_1 : someFunction()
    you'd have to do:
    O_1: O_1=someFunction()
    O_2: O_2=someOtherFunction()
    O_3: min(O_1 O_2)
    note that you have to ensure that the outputs are in the right order - so that any variables are defined before they are used (in IC614/IC615 this is done automatically so that dependent expressions are evaluated in the correct order).
