  3. Default font size for Virtuoso Visualization & Analysis
  • Replies 12
  • Subscribers 133
  • Views 20106
PSGcad
PSGcad over 13 years ago
maybe my screen resoution is too large for this tool, but it annoys me everytime I plot a curve that I have to squint to see if it's mV or uV because the font is just too small. I can easily change it, I know, but it'd be great if it could be changed by default. Same goes for my ocean scripts plots.
 thanks.
- Patrice
    Patrice,
    The fonts can be changed using a .cdsenv setting. You didn't say which version you're using though...
  • srk526
    srk526 over 12 years ago
     I'm using IC6.1.5.  What can I put in my .cdsenv to change the default font that VIVA uses when plotting waveforms (for the axis, titles, etc.)?  Currently it seems to be using Helvetica (Linotype) - which doesn't print properly from my printer.
    Steve
  • yishai eilat
    yishai eilat over 12 years ago
    Hi andrew,
    what is the syntax in order to get default Yaxis font size of 16.
    10x,
    From SKILL:
      envSetVal("viva.axis" "font" 'string "Default,16,-1,5,50,0,0,0,0,0")
    In your ~/.cdsenv :
      viva.axis font string "Default,16,-1,5,50,0,0,0,0,0"
  • Clidre
    Clidre over 12 years ago
    I'm new with Cadence and I would like to do the same thing: changing axes font size.
    I have created an empty file .cdsenv in my work directory and I copied the line:
    I started Cadence (6.1.5-64b) again from my work directory and I tried to draw a plot, but the axes font size hasn't changed.
    Am I missing something?
  • FormerMember
    FormerMember over 12 years ago
     The documentation on the methodology to set new defaults for ViVA is not accurate.The defaults can be placed in your .cdsinit file and must be preceeded by lading the ViVA context as detailed below.
    ; ViVa default fonts to Clean
    ; Added from Wayne Ingram's note on 7/24/2013
    ; If customer is setting font related cdsenv variables in .cdsinit (via envSetVal API),
    ; there's a requirement to load the 'viva' context _before_ any envSetVal call is made.
    ; This can be achieved by the following in the .cdsinit file:
    loadContext(strcat(prependInstallPath("etc/context/") "viva.cxt"))
    callInitProc("viva")
    envSetVal("viva.graph" "titleFont" 'string "Clean,12,-1,5,55,0,0,0,0,0")
    envSetVal("viva.axis" "font" 'string "Clean,12,-1,5,50,0,0,0,0,0")
    I'm a bit surprised by this (I found Wayne's solution and the corresponding CCR). For me it works fine without the pre-loading of the viva context, and I really don't think that should be necessary. Maybe it's been fixed (I was using IC615 ISR17 and IC616 ISR2 when testing this).
    Anyway, I've asked R&D to check - because the comment on pre-loading the viva context came from them initially.
  • SharksFan
    SharksFan over 11 years ago
    Is there any follow-up available on this topic? I could do the testing across versions myself, but if there's an answer already available then it would save me the work.
    No, I didn't get an answer - and to be honest, I've been a bit busy to chase it up (especially as I couldn't see the problem in the versions I was using, as I mentioned). I may well see the R&D person this week as I'm in the US, and so I'll ask him if I see him.
    Kind Regards,
  • findsriharsha
    findsriharsha over 7 years ago in reply to Andrew Beckett
    Hi, Could you please suggest how to increase the ADEXL fonts size?
