  3. Error when plotting histogram in adexl
  • Subscribers 129
  • Views 18063
Kowshik
Kowshik over 13 years ago
Hello!
When I try to plot a histogram after running a monte carlo simulation from the adexl window I get the following error:
ERROR (ADEXL-2404): Cannot find a setup database entry for handle 3676.
Provide a valid database handle and try again.
I cannot reach the point where i select the signals whose histograms are to be plotted. Instead it freezes at the point where i choose the test for which I plot the histogram.
I have plotted histograms through adexl recently and have not encountered this error. I am using IC 6.15
Thanks!
    I'll do some checks tomorrow (can't easily now) - what subversion are you using? (Help->About in the CIW will tell you). That will give me the extra info to do some investigation.
  • Kowshik
    I am using IC 6.15.500.9
    Thanks!
    I found a number of issues reported for that error message, but unrelated to plotting histograms - the message seems to be possible in a number of different scenarios.
    My advice would be to try IC615 ISR14, and if it still happens, contact customer support who can then take a look at your data.
