  3. how to export to GDS in batch mode IN IC06.13
  • Subscribers 129
  • Views 14493
ghrshomali
ghrshomali over 13 years ago
I am trying to export a layout to a GDS file in batch mode. I used to run PIPO STRMOUT command for IC5.14 but it seems this command no longer exists for IC6. I am wondering what is the proper command and what is the syntax?
  • skillUser
    skillUser over 13 years ago
    The "pipo" command line functions are now "strmout" and "strmin". Solution 11306144 has some information on the command line switches that are accepted, plus you can take a look at the documentation.
    Lawrence.
  • ghrshomali
     Hi Lawrence,
    I don't have access to that solution but I figured out how to use "strmout" command.
    Thank you very much.
    Reza
