  3. a weird problem about calculator of cadence ic5141
  • Replies 7
  • Subscribers 129
  • Views 16341
whusteryzh
whusteryzh over 13 years ago
Normally when I call out the Calculator from the ADE,a window with functions will display.but recently,a weird problem occurded,the founctions in the window disappear,as you can see the picture in the attachment below.Can anybody explain why?
    I doubt anyone will be able to explain why - your post only contains text (I presume you meant to include a picture?).
    Please describe your problem more carefully.
  • whusteryzh
    Hi Andrew!
    Thank you for your reply!
    I'm sorry for my fault of uploading the picture in a wrong way.I reedited it just now!
    Which subversion are you using? I found a record of such a problem, but it was fixed a long time ago in a hotfix of IC5141 (should be in USR3 or later, I think).
    What does Help->About in the CIW show for the subversion (or type getVersion(t) in the CIW)?
  • whusteryzh
    The subversion is "sub-version 5.10.41.500.1.20"
    OK, the fix was in a version later than that (I think from memory it was 5.10.41.500.2.23). The version you are using is _really_ old - I'd advise moving to something more recent (eg the latest hotfix of IC5141 - even that is over a year old).
  • whusteryzh
    Well,Thank you for patience and help!
    By the way,I can open the Standalone skill Calculator or choose the AWD waveform tool in order to use the functions.
    whusteryzh
    The reported problem (that was fixed) only showed in the wavescan calculator when invoked from ADE, so that probably explains why you can use it standalone.
    Best thing would be to move to a later hotfix though, because the one you have is really old (I think between 7 and 8 years old)...
