  3. How to change ocnPrint() column names?
  • Subscribers 129
  • Views 14615
Steve Mikes
Steve Mikes over 13 years ago
When printing an expression with ocnPrint, the column name defaults to the expression, which in most cases is very long. Is there a way to set the column header?
    Assuming you have two things to be ocnPrinted, wave1 and wave2, you could do:
    drGetWaveformYVec(wave1)->expression="short1"
    drGetWaveformYVec(wave2)->expression="short2"
    ocnPrint(wave1 wave2)
  • Steve Mikes
    Steve Mikes over 12 years ago
     Thanks Andrew, that's exactly what I was looking for! Where can I find this in the documentation? I found the drGetWaveformYVec function in the ADE-L Skill manual, but it doesn't say anything about there being an "expression" field.
    It's not currently documented; there's a CCR requesting this, and better still there's a CCR requesting a public function to set the expression.
