  3. Failure to select signals to save
  • Subscribers 129
  • Views 14646
KMan2011
KMan2011 over 12 years ago
I'm using  IC 5.10.41.500.6.151, with spectre 10.1.1 32bit, and irun 10.20-s076.
I have a design fired up with a config view and I'm trying to minimise the number of signals I save.  In one particular cell, I'm unable to save the required nets.  WHen i click on the net, CIW shows the following entry:
Warning  (MSPS) : (PARA-308) The current configuration doe not include a valid extracted view.  This can be caused by the extracted view generated with a version of Divia prior to 5.0.0.  If this is the case, please re-extract the veiw with a version of DIVE 5.0.0 or newer.
I'm using a schematic view of the cell of interest, and we use Assura rather than DIVA if we were to use extracted views.
I also noticed at the top of the schematic window in the title bar, it says (out of context).  I usually see this when I'm trying to descend into a view, not set by the HED.  The cell instance I'm descending into is a 'bus' type instance...one of 11 identical cells, differentiated with a I9<11:0>.  But this shouldn't be the case, since I can select signals in another 'bus-annotated' device.
  • KMan2011
     Actually, I've managed to get rid of the 'out of context message', but the inability to select signals to save within this particular cell remains
     Please contact customer support. I'm not sure why this is happening (not that we can fix it in IC5141 anyway, since there are no further hotfixes for IC5141, but maybe it's a usage issue, in which case we'll probably need to see  your data).
  • KMan2011
     Ok...I'll get in touch
