  3. Export .tf into .lef file
  • Subscribers 130
  • Views 15130
sohaiba
sohaiba over 12 years ago
 I have converted virtuoso .tf into lef file from file > export > LEF. But when I use it with encounter as a tech lef, there are a lot of  errors like the following
**ERROR: (ENCLF-268):    " There is no spacing table defined bewteen cut class
'square' and 'square' in layer 'VIA6'. It may cause certain commands not working"
and
**ERROR: (ENCLF-53):  " The layer 'VTL' is not found in the database.
A layer must be defined before it can be referenced."
Am I following the right procedure of converting .tf into .lef?
  • sohaiba
     Moreover, also when I try to load technology file in virtuoso , following is displayed in CIW
    INFO (TECH-180006): Compiling class 'controls'....
    INFO (TECH-180006): Compiling class 'layerDefinitions'....
    INFO (TECH-180006): Compiling class 'layerRules'....
    INFO (TECH-180006): Compiling class 'viaDefs'....
    INFO (TECH-180004): Compiling class 'constraintGroups'....
    After this a number of warnings are displayed like ::
    *WARNING* (TECH-230005): Invalid parameter paraLength for 'minExtensionEdge' rule.
    *WARNING* (TECH-200021): Failed to set constraint parameters for specified constraint -- '(minExtensionEdge "M1" "VIA1" 'cutClass rect 'width 0.165 'paraLength 0.1 'within 0.13 0.015 'ref "VIAx.EN.12")'.
  • Alex Soyer
    Alex Soyer over 12 years ago
    Hi Sohaiba,
    You faced this error because the layer "VTL" is not defined into the "function" section of your techfile. You need to define the function of this layer which in your case should be defined as 'nimplant' or 'pimplant'.
    Please make sure you techfile contains the spacing information for the square to square cutclass spacing.
    You use the right command to export technology information from Virtuoso but maybe your techfile does not contain all required information.
    Aex
  • Alex Soyer
    From what I can read into the documentation the rule should be defined as follow:
    (minExtensionEdge "M1" "VIA1" 'cutClass "rect" 'width 0.165 'paraLength 0.1 'within 0.13 0.015 'ref "VIAx.EN.12")
    "rect" could be replaced by cutWidth or by (cutWidth cutLength)
    Alex
